IR 2318 horizontal ligne
  • eliaso
    • Jul 2014
    • 52
    Hello .
    I have this problem in IR 2318 did someone know what is this ?
    This only have I found:
    God created mankind upright,
    but they have gone in search of many schemes.
  • DAG COPIERS & COMPUTERS
    • Oct 2010
    • 860
    Re: IR 2318 horizontal ligne
    Originally posted by eliaso
    Hello .
    thanks in advance .[ATTACH=CONFIG]29624[/ATTACH]
    Tell us what steps you have taken so far to cure the fault e.g replacing the drum unit?
    • eliaso
      • Jul 2014
      • 52
      Hi ,no I didn't make anything
      but the drum is not original ,maybe there is an electric leek with the charge roller ,I will change the drum .
      • copier tech
        • 8144
        You answered your own question. Drum is not original, fit a genuine drum unit, your problem will be solved.
        • eliaso
          • Jul 2014
          • 52
          I changed only the drum, and it 's go well
            • Oct 2010
            • 860
            Hope you you changed the cleaning blade also, if not the lines will soon be back, as the old blade will scratch the new drum cylunder again.
