Print on 120-160 gms paper
  • Peter Sim
    • Sep 2008
    • 445
    Hi to all ,need your opinoin
    What is the most suitable canon ir advance copier machine to print in 120-160gms paper?
    Thank you in advance
    • 23010
    Re: Print on 120-160 gms paper
    Nearly any copier you select will be able to print media in that range. This is only Thick1 or Thick1+. =^..^=
    • SAZ911
      • Mar 2013
      • 193
      Hi,
      Color or Black and white, Volumes ???, glossy vs Plain Paper....need more info, as mentioned above most of the machines will do it, just dont waist your time with a IRAC2020I
      Cheers,
      SAZ911..........
      • Peter Sim
        • Sep 2008
        • 445
        Originally posted by SAZ911
        Hi,
        Cheers,
        Is black and white only and per click is about 3000 to 4000 copy and need to use the cassette to print .
        Because the manual feed is olny 50 sheet per tay,is not siutable.Dont no is glossy or plain paper yet and only thing we know is the thickness of the paper.
        • SAZ911
          • Mar 2013
          • 193
          Hi,
          if its only black and white, and if you are sure that you are only going to do 3-4000 per month then i would say something like a IRA42XX.
          Good Luck,
          SAZ911..........
          • Peter Sim
            • Sep 2008
            • 445
            Hi,
            Good Luck,
            Sorry is not per month,is each print from Pc is 3-4000 copies,need a copier that can print thru cassette with the paper weight around 120-160gms .
            • SAZ911
              • Mar 2013
              • 193
              Hi,
              If that's the case then you will need to try-and work out an average monthly volumes, so that you can supply the relevant equipment.
              Maybe a paperdeck will be needed since the jobs can be big.
              Get as much info as possible, it will make finding the right machine for the right job so much easier.
              Cheers,
              SAZ911..........
              • Peter Sim
                • Sep 2008
                • 445
                Hi,
                Cheers,
                After a fews week finding,canon offer the iRA8095,is able to print from cassette with paper weight at 160gms.I have not much experience on big machine.
                I want to know that is this copier maintainance high?Speed will be the same as print on the thick paper(160gms)?Fuser unit easy to maintainance?
                For silicon drum ,should the drum keep warm all the time?
                • vigour
                  • Aug 2010
                  • 1038
                  They do not need a lot of maintenance.
                  Fuser rollers easy to change, they last long.
                  you might have to change web gears.
                  nothing too much out of the ordinary
