Irca2225i remaing data
  • mramlawi
    • Jul 2011
    • 838
    Dear all,
    i have canon irca2225i i installed it as a brand new machine since 1 month and now my client called me its not booting just giving on the screen remaing data dont turn of the machine ,i reinstalled all the conectors with no changes.
    Distinguished road makes you jewel in rough
    • 2621
    Re: Irca2225i remaing data
    Have you reloaded the firmware?
    • mramlawi
      • Jul 2011
      • 838
      No homestly not yet ,i will try ti reload software
      • teckat
        • 16084
        Originally posted by mramlawi
        Dear all,
        Replace the SATA-Flash PCB on Main Controller 1
        imageRUNNER ADVANCE C2225 / C2230 = FM0-2653-010
        • mramlawi
          • Jul 2011
          • 838
          Thanka for ur response i tried to search on the parts catalog the code u gave it to me i didnt found it honestly
          • teckat
            • 16084
            Part is not in Parts Catalog/
            see pdf
            Counter_Memory_&_SATA-Flash_PCB_Chart_2015.pdf
            Do not transfer the following parts to another model (which has a different serial number).
            If you fail to do so, the Main Body does not activate normally and this might cause to fail the restoration.
            • Main Controller PCB 1
            • Flash PCB
            Transferring the parts from Old PCB to New PCB
            • Flash PCB
            • TPM PCB
            Re-setting/registering the data is not necessary after Main Controller PCB 1 is replaced.
            • Canuck
              Tech Specialist
              • 1713
              Read this
              • teckat
                • 16084
                iR ADV C2020/C2030
                v45.01.01 (SST)
                v45.01.01 (USB Files)
                v45.01.01 (LCDS Files)
                -----------------------------05/22/2015
                iR ADV C2225/C2230
                v52.01.01 (SST)
                v52.01.01 (USB Files)
                v52.01.01 (LCDS Files)
                • mramlawi
                  • Jul 2011
                  • 838
                  Thanks teckat and all i format the sata flash and it works
