C5045
  • T911
    • Jun 2007
    • 628
    C5045
    A TECh before me replaced the fuser film assembly and customer called back for jamming.when I got there the pressure felt tight so I adjusted the NIP.I can get 1 through the fuser and nothing moreit jams in the NIP of the roller and film. I checked the jam counts and I have a lot 0107 & 0109 jams. I tried from every tray and same thing. Ideas Appreciated
  • hidius
    • Jun 2015
    • 128
    Re: C5045
    check that the separation guide plate was removed from the old assembly to the new assembly. or if it was installed the correct way around
      Re: C5045
      When you open the right door and open the fuser guide the darker curved side of the separation guide should be facing you and the small holes should be facing the bottom.
      • teckat
        • 16083
        Re: C5045
        Fixing separation guide, FC8-5043-020, probably not transferred from the old assembly to the new one.
        Usually, the two leaf springs, Item 5, FC6-9471-000, are missing as well.
        When re-assembling the upper fixing belt assembly it is possible to install the separation guide plate incorrectly.
        When installed properly there should be .5mm or less gap, it should not touch the belts surface, between the separation plate and the fixing belt. If installed incorrectly the gap between the fixing belt and the separation plate would be much larger, approximately 1 to 2 mm.
        • copier tech
          • 8171
          Re: C5045
          You should never need to adjust NIP pressure if you do you're only compensating for worn pressure roller, bushings or bearings, ajusting NIP can create problems later on!
          • THUK
            • Jul 2008
            • 195
            Re: C5045
            Does it jam if you run A4R.
            • T911
              • Jun 2007
              • 628
              Re: C5045
              Great stuff guys. It was the plate that he put on backwards and i did put the nip back to where it is suppose to be. Thanks
