fuser fixing film problem
  • princepriyu
    • Aug 2025
    [Misc] fuser fixing film problem
    hi experts i need help in fixing a problem related to fuser film for my photocopier machine
    CANON IR3570
    i have changed the fuser film but it is getting damaged at one end.
    it is pushing itself to one end while the machine is in action and the the end is getting rubbed at its tearing up.
    please can anybody help me in fixing it up
    i have changed 3 fuser films till now
    i had called local expert he tried to adjust the spring tension but may be he was new he too failed
    i have attached some images of the damaged film for your better idea
    please anybody help
    • 23009
    Re: fuser fixing film problem
    Have you examined the pressure roller and bearings? Worn pressure roller and/or worn bearings will cause this affect. =^..^=
    • princepriyu
      Pressure Roller is new
      did not check the bearings
      i have a doubt
      does the screws attached to tension springs effect this
      if not evenly balanced
      if one side is much tighter than the other
      will this also causes
      how to technically correct this
      how to distribute the pressure on both the ends
      • amraklve
        • Jul 2015
        • 17
        I found that when i checked the heater bar it was well worn in most occasions. Didnt have problems after replacing the heater assy and film as one part
        Sent from my SM-G900I using Tapatalk
          • 23009
          I have always disassembled these fusers without changing the pressure adjustment, so I have never needed to set the fixing pressure. =^..^=
