canon irac 5051 fading cyan
  • Jerrygbs
    • Dec 2008
    • 193
    the following parts have been changed, cyan drum and developer, transfer drum assembly, entire itb carriage with toner hoppers, contacts checked , hvt1 and hvt2, cyan laser, machine reset to factory specs then readjusted. All parts work fine in another machine. We are tracing HV wires for leaks. Any help would be appreciated.
  • teckat
    • 16083
    Re: canon irac 5051 fading cyan
    dumb ? was this done
    COPIER > FUNCTION > DPC > DRMRSETC ?
    It must be determined if it fades due to Primary Transfer or Secondary Transfer.>>??
    Secondary Transfer HVT's (HVT3)
    If it is determined that the fading occurs at Primary Transfer (faded on the ITB belt but not on Drum), then the Primary Transfer HVT (HVT2) may be at fault.
    Intermittent fading of Magenta and Cyan
    % of Life on below>>>?
    Inner Secondary Transfer Roller
    Outer Secondary Transfer Roller
    • Jerrygbs
      • Dec 2008
      • 193
      teckat as usual you are correct, hvt1 was bad, replaced it and we are rocking again.
      Thank you
      • teckat
        • 16083
        Thank you
        welcome
