the following parts have been changed, cyan drum and developer, transfer drum assembly, entire itb carriage with toner hoppers, contacts checked , hvt1 and hvt2, cyan laser, machine reset to factory specs then readjusted. All parts work fine in another machine. We are tracing HV wires for leaks. Any help would be appreciated.
canon irac 5051 fading cyan
Re: canon irac 5051 fading cyan
dumb ? was this done
COPIER > FUNCTION > DPC > DRMRSETC ?
It must be determined if it fades due to Primary Transfer or Secondary Transfer.>>??
Secondary Transfer HVT's (HVT3)
If it is determined that the fading occurs at Primary Transfer (faded on the ITB belt but not on Drum), then the Primary Transfer HVT (HVT2) may be at fault.
Intermittent fading of Magenta and Cyan
% of Life on below>>>?
Inner Secondary Transfer Roller
Outer Secondary Transfer Roller**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
