iR ADV C2030i ERROR CODE E020-0391
  • pinheiro
    • May 2009
    • 51
    [Error Code] iR ADV C2030i ERROR CODE E020-0391
    Hi,
    Can please I get help on this ERROR code, happened in 4 units at this stage and when I try to follow the procedure from service bulletin, it keep damage the Bk drum.
    Any feedback it will be appreciated.
    Thanks in advance
    Pinheiro
  • Northwestservice
    • Jan 2011
    • 140
    Re: iR ADV C2030i ERROR CODE E020-0391
    E020 0391 05 Title ATR Sensor (Bk) error or toner supply error
    Detection The average value of detected inductance sampling value
    is equal to or higher than the specified value (0x0F)
    Remedy 1. Check if the Drum Unit (Bk) is installed.
    2. Check the Drum Unit Relay PCB (Bk) (UN29)
    3. Check the Drum Unit Memory PCB (Bk) (UN33)
    4. Check the harness/connector between the DC Controller
    PCB (UN09/ J25) and the Drum Unit Relay PCB (Bk)
    (UN29).
    5. Replace the Drum Unit (Bk).
    6. Replace the DC Controller PCB (UN09)
    I had this once in a remote village service call I ended up reusing the old drum chip
      Read all about it
      020 irc2000.pdf
      • pinheiro
        • May 2009
        • 51
        Hi
        Thanks for you help, but unfortunately I did try all this procedures before with no success, so I was expect to get something new or in more details cos it become more complicate to stop 4 copiers all with exactly the same problem.
        Thanks any way...
        Regards
        • pinkia
          • May 2009
          • 19
          Originally posted by pinheiro
          Hi
          Thanks any way...
          Regards
          Dear Friend
          clean laser unit and patch sensor, then try to install drum unit.
          Second solution is illogical but it works for me.
          reinstall second drum unit give a command of 4 or 5 copies interrupt the same then install new drum unit.
          • pinheiro
            • May 2009
            • 51
            Thanks for you help...
            I'm busy doing the first solution now...
            Please can you be more specific and clear on second solution, sorry for that, I'm from Portuguese country and my English are so bad, and it sound good solution.
            • copier tech
              • 8202
              When you say " it keep damage the Bk drum" what exactly do you mean?
              • pinheiro
                • May 2009
                • 51
                Hi,
                It sound like the Drum when "init" it turn in wrong way and it drop the starter and get the error code, a soon that happened, the drum you can't use anymore even in deferent device.
                When you initialise the New Drum into other machine, you can steel get few copiers or printers on fault one but after 5 or 6 pages the system it measures and it makes accurately the same...
                The fault drum, even on new machine it pickup that error.
                I have now 5 units getting the same problem at my workshop.
                Please any help will be appreciated.
