Jam 01 00 48 on irac2020's ADF
  • V-P
    • Apr 2011
    • 679
    When customer uses single sheet - it runs smoothly.
    When customer uses 2 or more sheets on the ADF of the irac2020 it pops up the jam code 010048 (pointing to SR3 sensor) ?
    When customer uses double sided option - it runs smoothly. How come ?
    Firmware ? Or some bent plastic ?
    Haven't seen the copier yet, but I want to be quick in and out.
  • V-P
    • Apr 2011
    • 679
    Re: Jam 01 00 48 on irac2020's ADF
    Looks like it is not going to be a quick one.
    Was at the customer today and checked the mechanical part. Everything is fine.
    If you only SCAN the sheets - No Problem.
    If you want to COPY the sheets - than it pops up the jam code.
    I am starting to believe the problem is not in the ADF itself.
    The machine has an internal finisher. Could it be causing it ?
    Any ideas ?
    • dan7777
      • Dec 2012
      • 680
      Any ideas ?
      Jam 0048 shows in the inner finisher delivery reversal sensor SR3 in the service manual. I have seen paper get caught up in that area but don't remember the jam code.
      • V-P
        • Apr 2011
        • 679
        I know it points you to the PS3. But it is not the PS3. Read carefully
        • dan7777
          • Dec 2012
          • 680
          I reread it carefully. If you copy with adf and shows that jam code I would start looking there. I have replaced those sensors before. They are the funky old cheap style I think. If you don't use the ADF and no jam code seems like a very strange problem. Sorry I am of no help.
          • teckat
            • 16083
            01 is not for internal finisher / 02 ACC ID is for that unit
            C2030/C2020
            Color Image Reader Unit-D1/D2
            Jam = ACC ID 01 0048 = is Stationary Delivery reversal sensor SR3
            IT'S A PAIN TO REMOVE THAT SENSOR
            • V-P
              • Apr 2011
              • 679
              Guys !
              You are missing the point !
              When I scan to email or USB or FTP : The process is fine. No jam codes.
              Only when I have to COPY - than the Jam happens
              • dan7777
                • Dec 2012
                • 680
                C2030/C2020
                [ATTACH=CONFIG]30183[/ATTACH]
                Oops. Sorry. The jam code in my manual had the finisher on the same page and I did not notice. Maybe I need to update my manual. I was looking at the 2020 service manual. Dang!!! I had rev 4. The new one was rev 9. The stupid thing showed the jam codes for the adf for the finisher. I am going to keep it because no one would believe me if I didn't! Thanks. I may have used this to troubleshoot a machine!!!
