Konica C280 fuser clicking
  • pfuller22
    • Jul 2025
    [Misc] Konica C280 fuser clicking
    Hello everyone. I have just changed a fuser on my c280 as the old was getting worm. I put the new one in all ok but its clicking for some reason and i can't work it out. Its a rotary clicking noise that wasn't there before i changed it. Any ideas at all? it still all works and prints as it did before hand
    • 23008
    Re: Konica C280 fuser clicking
    Worm?
    If the fuser had been sitting on the shelf for a while the pressure roller might have flat spots. The good news is that it might smooth out with use, and won't cause anything other than a noise. I usually don't replace the fuser for worms. =^..^=
    • pfuller22
      Thank you, should of taken it to the vets really but its quite a weight to carry down the road. The fuser has been on my shelf for maybe 2 months and before that who knows. Hopefully it will go in time then. It does almost disappear when printing its just the warm up its louder.
      Thank you
      • tonertechnologies
        Re: Konica C280 scanner driver not found
        I need a step by step guide to install scanner. After several downloads of scanner drivers Generic 36C-1 Series is still missing.
        I would appreciate urgent response.
