KM 8050 dumping K developer material
  • laserman06
    Conservative in Exile
    • Dec 2007
    • 323
    About 6 weeks ago, took a call on a 8050 for voids. Went to the machine and found that the K developer unit was shot. Replaced with a new unit. Checked to make sure that charge wire was installed properly, it was. Ran adjustments, looked great.
    About a week and a half ago, another tech took a call for the same reason. Again K developer material was gone. So not realizing that I had replaced the whole unit, he replaced it again.
    The customer just called it in again for the same problem. Any ideas what could cause this? Driving me crazy!!!
    The family that prays together, stays together!
    Smile God created you and He doesn't make mistakes!
    Relax, God IS in control!
    Be still and know that I am God
    Ps 46:10
  • random
    well the only way a dev tank can empty is via the drum unit. This would only happen if there was a massive discharge in the drum due to a crappy charge unit. I would atleast check the drums, cc and bias.
