C351 and IU's
  • Leela
    • Dec 2024
    C351 and IU's
    We have a Bizhub C351 w/ the IC-402.
    When the Black IU reached its life and wanted to be replaced, we replaced it with a new one. Except on the life indicator, the brand new Black IU was already 'half used up' apparently.
    Just recently the Yellow, Cyan, and Magenta IU's all want replacing. AT $600AUD each, fine, we got them. I just replaced the Yellow IU, but the life indicator says that the Yellow IU is almost all used up.
    So far I haven't replaced the Magenta or Cyan IU's yet.
    The linux boxes can print to the C351 fine, but the window's PC's say that it is 'Offline' because its IU's are at life and need replacing before it will print using the IC-402 driver.
    Any ideas what the hell is up with the insanity with the life indicators?
    Also we feel we only got about a quarter of the pages we should be getting per IU anyway. Whats up with that? About how long should the IU's be lasting us?
    I'm an IT, unix, windows, osx geek. Complicated photocopying equipment is NOT my area of expertise, so I feel totally lost
  • random
    Well when you initially put an IU unit in it will only drop to half then do about 5mins of whirring and then the counter should be reset. To stop messages on your windows machines turn off snmp.
    • Leela
      SNMP is off. Windows PC's still can't print to the copier.
      I'll check what the IU life remaining reads now...
      • random
        how are you printing from windows? RAW/LPR/SMB?
        • Leela
          I use the IC402 driver, and add a IP printer by creating a TCPIP printer port, and point it at the copier's IP address..... I believe its using raw therefore.
          I certainly don't use SMB.
          • random
            impressive you get snmp messages when it is turned off. Print out the config sheet from the fiery and check that SNMP is turned off on that also.
            • laserman06
              Conservative in Exile
              • Dec 2007
              • 323
              When you put a new IU in the machine, it has to do it's adjustments. If it does not complete these adjustments properly, the IU will not be reset.
              Enter service mode and check your warnings. Clear up the warnings and the IU should reset.
              The family that prays together, stays together!
              Smile God created you and He doesn't make mistakes!
              Relax, God IS in control!
              Be still and know that I am God
              Ps 46:10
              • Leela
                Right. So how does a noob like me enter service mode?
                • srazvan2002
                  Try utility - counter - stop - 0 - 0 - stop - 0 - 1
                  then enter password
                  then stop - o - stop 9
                  enter iu life stop
                  then select not stop
                  this makes the copier not to stop if iu is at 0 copy life
                  and lets you print but the message still apears
                  hope it will work for you on c350 works
                  • Leela
                    then enter password
                    enter iu life stop
                    This doesn't seem to do anything
                    Is that how you go into service mode?
                    • nightshade
                      Chromographic Supremesist
                      • 158
                      The life on IU's can vary greatly depending on use. If you do alot of 1-2 copies (small runs) and alot of turning off and on, and alot of sitting between runs they will last a considerable shorter life then if the machine was put to heavy use.
                      That is probably why your units don't last very long, they are killed by rotations, not copies.
                      When you replace them, put them in, close the door and walk away for 15min. You cannot disturbe the process controll that needs to be run in the least.
                      Now is time to call an authorised service provider and bite the bullet on the bill.
                      • laserman06
                        • Dec 2007
                        • 323
                        You can see if there are any warnings by simply looking at the display. If a warning comes up, you should see an oil can icon. Touch it and the warning will be displayed.
                        Ps 46:10
                        • mitchl
                          • Apr 2007
                          • 500
                          Did the machine ever come to ready after the IU's were replaced? Look for an oil can on the control panel as others have suggested and if indeed its their touch to see what the P code is............ Depending on the firmware version in the machine there is a setting in the stabilizer screen for span 1 and 2 make sure this is on 2 as it cuts down on the amount of stabilization cycles that the machine does and increases IU life quite a bit. Where the IU's you bought brand new or advertised as brand new? It sounds like maybe someone sold you some used units, reason being when new units are installed the machine stabilizes and then resets the life counter, you said that the machine was calling for IU's which means that the life counter bars should have had all 10 blocks filled in. You also said that when you installed the new units that the life counters then read half full......... That's not right, it should still show full life counters till the machine stabilizes and resets then the counter will show no use. If a Pcode comes up during this process, its my experience that the life counter stay full till the problem is corrected and the machine stabilizes, so the machine showing them as having half life is probably correct and someone sold you used stuff.
                          • mitchl
                            • Apr 2007
                            • 500
                            Use the procedure above to enter service except when you hit the utility key look to the left and you will see the counter info and a button that says "Detail" touch it then follow the rest of the procedure that someone posted earlier.
                            • Leela
                              Thank you thank you thank you, and to everyone else who has also posted, THANK YOU.
                              What you said worked to get me into service mode.
                              Utility Counter, Detail, Stop, 0, 0, Stop, 0, 1.
                              I've had alot of fun in there :-)
                              1. I actually went to initialisation, and before resetting error states i thought i'd try reset data. Turned out to not be the BEST idea, since it reset everything on the machine back to defaults and I had to reconfigure it all for our network again so people could print, doh
                              2. In intialisation, error states, i reset that. Made no difference.
                              3. The "oil can" I think you people are referring to, displays P-22. The fiery controller unit displays "failure warning P22".
                              4. I disabled bitching about unit life.
                              5. I went to image unit stabilzation, and it indeed set for span 2 already.
                              6. I went to Life counters, and this is what i get for the image units:
                              Cyan: 3132M
                              Yellow: 3132M
                              Magenta: 3132M
                              Black: 3797M
                              When I originally changed the Black UI a few months ago, it only went to "half" on the unit life counter.
                              When I swapped over the cyan, yellow, and magenta UI's 3 days ago, they went only down a tiny bit, as in 9 or so out of 10 bars on the unit life counter.
                              I have no idea if the process that runs after the UI's are replaced was allowed to run.
                              I am pretty sure these were all brand new unused UI's, coming from our reputatable supplier for all our printing needs (we have various HP large format plotters, xerox printers, and more) and never had a problem with them.
                              But i'm not sure.
                              So thank you all for showing me up to get into service mode. Still not 100% sure whats up with the life indicator on the UI's and what P22 means though.
