Konica Minolta C280 Margin / Edge
  • mearmi
    • Oct 2010
    • 346
    [CQ] Konica Minolta C280 Margin / Edge
    Hi
    Konica Minolta C280 Getting Margin on the bottom edge while scanning from platen glass and ADF. Please find the attachment.
    Tried adjusting leading edge.
    Please advise
  • allan
    RTFM!!
    • 5459
    Re: Konica Minolta C280 Margin / Edge
    First complete printer area adjustments to spec then do scaner area to spec.
    Whatever
    • emujo
      • Jun 2009
      • 3009
      There is an A4 size test chart that comes with every new MFP. You need to run this page through the feeder to properly set adf zoom and read adjustments. Emujo
      • mearmi
        • Oct 2010
        • 346
        Is there a procedure to perform this test? Thanks a lot
        • allan
          RTFM!!
          • 5459
          Yes it comes with the setup manual. Its not an automatic procedure. You can make your own chart.
          Draw line on the page in both directions. Set the magnification based on the length of the lines of the chart you made.
          It's to get the 1:1 aspect ration sorted out. You can set centering and lead edge like that as well.
          Whatever
          • emujo
            • Jun 2009
            • 3009
            Other that having to run the test chart face up and face down depending on which adjustment it is automatic. Service mode, adf adjustments, and the install guide does give step by step instructions. Emujo
