Bizhub 600 Code C-2401
  • rizwan143
    • May 2015
    • 42
    [Error Code] Bizhub 600 Code C-2401
    Hello to All,
    I have a Bizhub 600 with a code of C-2401. I changed the ECL lamp corona assembly with another machine but same code. Also bought new PRCB & checked that too. Same code.
    Also Trouble Reset done by pressing Utility while powering on the Machine.
    I am unable to access Service mode by going with Stop 00 Stop 01. IS there any other way to access service mode also ?
    Any solution for the code C-2401
  • allan
    RTFM!!
    • 5462
    Re: Bizhub 600 Code C-2401
    Check the end-block connector on the drum cradle and the frame side. The connector on the frame side tends to crack.
    Whatever
      • 15050
      The is a bulletin concerning the code.
      PROBABLE CAUSES:
      1. C-2401 normally indicates a failed erase lamp, although it is caused, in this case, by a bind in the drum carriage.
      Remove and inspect the drum carriage assembly. Run the Toner Cartridge Set mode as well as the Developing unit/Drum.
      2. Open ICP6 on the PRCB.
      Check for broken or shorted wires in Tray 3 area and repair as necessary. Replace the PRCB (p/n 57AA -902 1J). After replacing the PRCB, go to the Service Mode and set softswitch 32, bit 1 to "0" (OFF). Then re-flash the firmware and, after restarting the machine, set softswitch 32, bit 1 to "1" (ON).
      Hope this helps
      • FixStuff
        • Aug 2015
        • 16
        Had this recently. Replacing the HV Unit fixed it in my case. I found the answer on another thread on this forum but can't find it now.
        • rizwan143
          • May 2015
          • 42
          What is the HV unit?
          • rizwan143
            • May 2015
            • 42
            PROBABLE CAUSES:
            Hope this helps
            If you dont mind please tell me the Flashing procedure & required files. I changed the Sw 32 to Off but dont know about flashing it.
            • allan
              RTFM!!
              • 5462
              Try leaving the front doors open when you start the machine and then accessing service mode.
              Whatever
              • rizwan143
                • May 2015
                • 42
                I am on the service mode. But how can i flash the firmware ?
                • allan
                  RTFM!!
                  • 5462
                  Do you have the firmware? Do you have a manual?
                  Whatever
                  • FixStuff
                    • Aug 2015
                    • 16
                    Power supply
                    • rizwan143
                      • May 2015
                      • 42
                      Sorry No
                      • rizwan143
                        • May 2015
                        • 42
                        Power supply
                        Can the Voltage supply cause this problem of C-2401 ?
                        The problem of C-2401 came in the morning with a warming problem. The machine said "Now warming up " & never being warmed even after 20 minutes. I opened the Drum assembly & inserted again & c-2401 started coming.
                        • allan
                          RTFM!!
                          • 5462
                          Did you change the consumables like the drum blade and developer? is the machine dumping toner.
                          Firmware is not going to fix this.
                          Whatever
                          • rizwan143
                            • May 2015
                            • 42
                            No, Nothing changed like drum, cleaning blade or developer. I have a Di-5510 machine also in my shop. I tried with that machine Corona assembly ( E L Lamp) on bizhub 600 but it still says same error c-2401 .
                            I spent money already on buying a new PRCB board from another city but still same problem.
                            I think this might help you to get new solution that :
                            I sent "Old board" to dealer in another city & he confirmed that " I tried this board on new Bizhub600 & it given same code on new machine too so the board is having a fault so buy a new one" So, he sent me a working fresh board from there but still same problem on my machine with new board.
                            Any Idea ?
                              • 15050
                              HV is the high voltage power supply, not the DC power supply. It supplies high voltage to the drum, dev, coronas.....etc. etc
