Bizhub 600 Code C-2401
  • FixStuff
    • Aug 2015
    • 16
    #16
    Re: Bizhub 600 Code C-2401
    Sorry for the confusion. I changed the DC Power Supply. DCPS1. I'm not saying it's definitely the cause but it fixed my problem.
    Here's the other thread I mentioned. Thanks to Mick01 for the answer.
    http://www.copytechnet.com/forums/konica-minolta/75057-bizhub-750-error-code-2401-a.html
    • rizwan143
      • May 2015
      • 42
      #17
      Do the Bizhub600 & bizhub 750 error code C-2401 have same meaning ?
      & should i check DCPS1 power supply now ?
      Can i check the voltage with multimeter to verify its working or not ?
      • rizwan143
        • May 2015
        • 42
        #18
        Update : I tried 2 Working PRCB on my machine but both gets Same error & then even board are not working on there machines too . What can be the fault which is making board blow out in moment.
        Please tell what things should i check in my machine so i wont loose other board too
          • 15063
          #19
          Did you read the bulletin I posted earlier? It says to check paper trays 3 and 4 for shorted wires that then blow the PRCB. Fix these shorted wires before replacing PRCB or it will blow it again.
          • rizwan143
            • May 2015
            • 42
            #20
            Right now going to check Tray 3 & tray 4 wires in bottom. Do you have any manual please to check for shorted wires. Please help me. I cant waste more board
            Please help me in finding shorted wires of tray 3 / tray 4
            • rizwan143
              • May 2015
              • 42
              #21
              Update : C-2401 Solved
              It was the wrong polarity of Wires of ECL lamp& now its solved .
              But now the machine keep saying " Now warming up." but never warms up.
              Please tell the possible solutions.
