I have an oce cm5520 i put a lightly used transfer belt on machine and did not change the fuse. Is there a diagram someone can share to show me where and how to change this fuse?
transfer belt fuse oce cm5520
Tags: None
Re: transfer belt fuse oce cm5520
I tried to find a picture online to show you, but could not locate one. Pull the transfer belt out a little ways. look on the side of transfer belt unit that faces the back of the copier. Just behind the handle you grab to pull the belt unit out will be a piece of black plastic held in place with one screw, it has two metal plates attached to it, about 1/2 inch apart. Remove this and the fuse will fall right out, so remove slowly. Replace fuse, screw back onto belt unit, and reinstall. Enjoy.A Ricoh Service Tech for 7 year. A Konica Minolta Service Tech for 7 years. Now, KM service manager for 4 years.
My Ricoh knowledge is slowly dwindling away at this point. Many things have been lost to time... -
jenna41
Thank you so much! you are a life saverjust what I needed to know..easy as 1 2 3
JenniferComment
