Bizhub 162 - Prn Error
  • james2015
    • Jul 2015
    • 14
    Hello,
    When I tried to print from Computer, the copier shows an error "Prn Error"
    Model : Knoical Minolta bizhub 162
    Thanks.
    • 23009
    Re: Bizhub 162 - Prn Error
    What driver are you using? =^..^=
    • rrrohan
      • Sep 2011
      • 1977
      Is the copier working for copies
      Can you Ping the copier
      Have you tried restarting your print spooler?
      we need way more info
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        these machines are pretty dumb, it is probably complaining about a mismatched paper size request.
        Been a while since I saw one of these p.o.s but you should be able to get the reason for the error out of the machine which will then make it self explanatory.
        Whats the point of telling you theres an error with no reason...
        • james2015
          • Jul 2015
          • 14
          I'm using GDI Driver (Version - 1.10,downloaded from konica minolta's website) in windows Xp.
          Thanks.
          • james2015
            • Jul 2015
            • 14
            Yes, the copier works for direct copies, but not from the computer.
            I've tried restarting the print spooler, even then , it didnt work.
            Thanks. Any other ideas ?
            • james2015
              • Jul 2015
              • 14
              Hello,
              Are you saying there's no solution to this ?
              Thanks.
              • Hansoon
                • Sep 2007
                • 3389
                Perhaps your machine has the optional IC-205 controller than it would need a PCL driver.
                Hans
                • james2015
                  • Jul 2015
                  • 14
                  Hans
                  Hello,
                  I dont think there's a problem with the driver, because the printer gets the command but fails to print, i think there is an error in the machine.
                  Any other solutions ?
                  • rrrohan
                    • Sep 2011
                    • 1977
                    I always tell customers to use PCL. I seriously doubt its anything wrong with copier if it copies. Downloading as that driver I'm confident that's all it is
                    Sent from my SM-G900I using Tapatalk
                    • Hansoon
                      • Sep 2007
                      • 3389
                      Yep, that's what I'm saying. The wrong command.
                      Hans
                        • 14813
                        I think if you press the "Printer" button it will display what the problem is.
                        Hope this helps.
                        • allan
                          RTFM!!
                          • 5462
                          Make sure if its got an IC on. Its happens to me a lot if i get to a site i have not been to before. Find the right controler driver if that is the case.
                          Whatever
                          • james2015
                            • Jul 2015
                            • 14
                            Hello,
                            I've installed the pcl6 driver and now it's working fine..
                            Btw, does anyone know if this copier has a scanning option (Scanning from Computer).. ??
                            THANKS..
                            • rrrohan
                              • Sep 2011
                              • 1977
                              Knew it was a driver issue esp when you said GDI.
                              Scanning from PC, don't you mean scan to PC?
                              AFAIK it does unless machine is so old and that's optional. Not old enough to know that vintage machine sorry
