P31
  • allan
    RTFM!!
    • 5462
    P31
    I encountered the encoder disc the first time. It did not end well. Managed to magel it with a brush. You have to take of the fuser pressure assy as well. So know i need a drive assy. Hope i can get a spare one out safely.
    Guess you can dip it in alcohol to clean it. Why a metal disc. Looks laser cut.
    Whatever
    • 14754
    Re: P31
    Huh?
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      Re: P31
      is this the black drum disk on the large machines ?
      I have changed a complete main drive unit on a C654 series and it's quite the nightmare.
      Even before it throws p codes it can start causing colour to black registration abnormalities randomly causing you to pull you hair out wondering wtf is going on. If the disk isnt 100% perfect just replace it as its going to come back even dust getting into the slits will cause failure too.
      • allan
        RTFM!!
        • 5462
        Re: P31
        jip that's the one, this is on a C550. Half of the machine is in the customers closet.
        The manual explains how to check the sensors and one tested bad. So i believe the disk was still ok.
        Whatever
        • allan
          RTFM!!
          • 5462
          Re: P31
          A total of 4 hours later the machine is working ok. What a mission to do this!!
          It does not seem like something to fix, replacing the entire drive section seems to be the way to go.
          Whatever
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            Re: P31
            Yes, it's an exceptionally unpleasant job.
            What can make it easier though is several cups of coffee and a rolling desk chair and take your time.
            Oh, and traffic cones and police tape with a sign saying "No, I do not know how much longer I will be" Instead of being asked every single 3 minutes till you go postal.
            • rrrohan
              • Sep 2011
              • 1977
              Re: P31
              Some companies require this and for you to fill out a threat matrix. I'm tempted to bring cones to every job.
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                Re: P31
                yep, anything in the resource sector is that anal. Fortunately I have no such customers in my area, just regular office people with the memory retention of a gold fish.
                • rrrohan
                  • Sep 2011
                  • 1977
                  Re: P31
                  Risk: paper cut
                  Likeliness: 1 put of 10
                  Consequence: non life threatening
                  Sent from my SM-G900I using Tapatalk
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    Re: P31
                    I never get paper cuts, tool or machine injuries but regularly get cardboard cuts or cardboard attempting to rip nails off completely - opening parts or paper boxes. That stuff is lethal.
                    • copier tech
                      • 8164
                      Re: P31
                      I did exactly the same thing, machine was working fine, but had P31 code, I cleaned the disk but managed to bend it, after that it would throw C- codes, black drum totation error. I had to replace the main druve unit!
                      If you need a C452/552 main drive unit I have a brand new unit spare you can have for a discounted price.
                      • allan
                        RTFM!!
                        • 5462
                        Re: P31
                        Thanks for the offer, but no need for it now. 3 Days after replacing the drive unit the customer decides to upgrade!!!
                        Whatever
                        • copier tech
                          • 8164
                          Re: P31
                          Ouch that's annoying!
                          • rrrohan
                            • Sep 2011
                            • 1977
                            Re: P31
                            On bright side you hard work paid off resulting in customer staying with you and upgrading.
