bizhub C224 and FS-533, Error code C1102
  • Bix
    replied
    Re: bizhub C224 and FS-533, Error code C1102
    Hi, I had read that thread but I could not understand what he means. Perhaps the translation is deceiving me.
    Thank you my friend
  • splblazer91
    replied
    There is a black spring loaded holder in the staple tray that sticks and grabs the paper(usually on hole punch). It is at about a 45 degree and I usually bend it to about a 35 degree angle and the problem goes away.
  • bizhub C224 and FS-533, Error code C1102
    Hallo at all,
    bizhub C224 with FS-533 often shows the error-code C1102. After replacing the jam and open/close the front door, the machine continued to copy or print.
    But this code unfortunately occurs several times a day.
    The service-manual describes a problem in the finisher FS-533.
    Have anyone of you experience with this code?
