Bizhub 654
  • manuelcorrea
    • May 2009
    • 46
    Bizhub 654
    I have a BH 654 with a little over 900,000 copies. Took out tray 4 feed section to change rollers & small clutches now I can't get it to feed even one sheet. Counts jams as 14-01. Tried feed section on another machine & it works good. Tried with other feed sections on this one and same problem. Was working before I took it out to rebuild. Anyone have ideas ?
  • copier tech
    • 8169
    Re: Bizhub 654
    Check for bent pins on the machine side, if you know the feed unit you removed works, maybe a pin was bent when you removed/fitted it back
    • rrrohan
      • Sep 2011
      • 1977
      Re: Bizhub 654
      ive never bothered changing clutches in feed assy on this model, just only do the rollers. I have a 754e thats over 2 million still going strong
      • manuelcorrea
        • May 2009
        • 46
        Re: Bizhub 654
        thanks for the reply copier tech , will check for bent pins early next week
        • 3boydad
          • Aug 2015
          • 27
          Re: Bizhub 654
          you should always change the oneways at the very least. clutches do go out and you will get call back after call back because it wont jam everytime. replace those cheap parts
          • HoonBoy
            • May 2011
            • 130
            Re: Bizhub 654
            My guess is you stretched the separation spring too much while replacing the separation roller...
            • 3boydad
              • Aug 2015
              • 27
              Re: Bizhub 654
              agrre i have seem registration issues.do single copy and open it during the process. you should find it.
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                Re: Bizhub 654
                other thing that I've had happen too many times to forget is paper being mashed into the socket at the back of the trays 3 & 4. Sometimes it is difficult to tell if there is paper in there take a very close look.
                • rrrohan
                  • Sep 2011
                  • 1977
                  Re: Bizhub 654
                  I'm told the new series allow customer to easily remove paper tray which should help avoid jams behind trays
                  Sent from my SM-G900I using Tapatalk
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    Re: Bizhub 654
                    There goes about 50% of the workforce.
                    • rrrohan
                      • Sep 2011
                      • 1977
                      Re: Bizhub 654
                      Nah I figure it will just make it 2 minutes faster for us to do for them let's be realistic
                      • manuelcorrea
                        • May 2009
                        • 46
                        Re: Bizhub 654
                        don't think its the sep. spring because feed section works well on other machine
