KMBHC652 Black Line Stripe on All Colors
  • kizi57
    • Dec 2010
    • 69
    While printing there is black line on every printout, on every print light to heavy stock
    Please advice what is the problem
    Please see attached PDF document, you can see sample color pages
    Thank you in advance
    Color.pdf
  • allan
    RTFM!!
    • 5462
    Re: KMBHC652 Black Line Stripe on All Colors
    Replace K drum unit or clean charge corona.
    Whatever
    • allan
      RTFM!!
      • 5462
      You can do the color IU's as well they look shot.
      Whatever
      • bachirabouzeid
        • Sep 2015
        • 17
        change the DRUM unit black
          • 23009
          What have you done so far? =^..^=
          • rrrohan
            • Sep 2011
            • 1977
            id check K Drum/ Dev and Transfer Belt
            I doubt its any more complicated than that
            • bachirabouzeid
              • Sep 2015
              • 17
              I am 100% sure that the K drum is the problem and you have to change it
              • rrrohan
                • Sep 2011
                • 1977
                But image defects on each colour looks the same that's why for at least that fault, look at ITBU
                Sent from my SM-G900I using Tapatalk
                  • 23009
                  I tend to agree with you, but not to the 100% stage. Machines can surprise you, and I am rarely that certain of anything anymore. =^..^=
                  • AjitN
                    • Mar 2009
                    • 287
                    As we all know, 1st transfer for black is always engage in ITB w.r.t. drum. hence it could be ITB Or Black Drum Unit. Also it would be appropriate to check Developer Unit.
                    Hope this helps.
                    • ALI1369
                      • Feb 2015
                      • 28
                      clean charge corona
