konica bizhub 350 aborts and resets every minute
  • DOE
    • Mar 2010
    • 258
    konica 350 that was fine when they left on friday and today it turns on and goes to ready and you can make copies but 10 seconds after making copies abort message comes up, says code 0x0000999 for about 20 seconds then resets itself and you can copy again. it also happens about every minute it sits there unused. goes to abort then resets. never had this happen before, any ideas thanks
  • Phrag
    • Oct 2012
    • 417
    Re: konica bizhub 350 aborts and resets every minute
    Well, if that code fits between 0x00000000 and 0x000fffff or something, then it points to the MFBS board. Thats straight out of the service manual. OS processing system failure.
    • bachirabouzeid
      • Sep 2015
      • 17
      Probably the problem is in the MFB but 1st try to reinstall the firmware
      • JR2ALTA
        • Feb 2010
        • 2033
        Let it reboot without the network cable plugged in. If it's fine then you have a corrupt print job repeatedly trying to get through. It's usually Google Maps for some reason. Track down which workstation or server and clear the queue.
          • 23010
          I had a bizhub 364e recently that would turn Off and On at 30 second intervals, that turned out to be a hard drive. =^..^=
          • allan
            RTFM!!
            • 5462
            I have found that reseating the MFPB the ram and the NVram sometimes fix this problem. Disable the and unplug the fax card helped before.
            Whatever
            • DOE
              • Mar 2010
              • 258
              THANK YOU!!!! This was the solution. i unplugged network cable and copier worked fine. had them clear the queue and it all worked great!!!!!! really appreciate everyones advice!!!!
              • sauce_boss
                • Oct 2011
                • 26
                This can also happen if they have the port in their driver set to LPR instead of RAW. Just something to check to keep it from coming back in the future.
                • DadO
                  • Dec 2007
                  • 404
                  Same happened to me last year. After doing all steps ( reseting mem boards, fax, machine...) machine worked like charm but when I plug network cable, it hits abort code almost instant...Now imagine argument between me and It guy who blamed machine....
                  • wseyller
                    • Sep 2012
                    • 1129
                    There is actually a special firmware for this model and the series above it that helps sometimes with the issue. I have even done this firmware flash and it would then allow the job causing the issue to finally print out.
                    The change log says that it is for issue when printing from Google maps site but it helps with other causes.
                    There are other situations that this firmware doesn't help with for example using the wrong print driver or when using Macs 😂
                    For 200/250/350 series it is 4040-0100-H3U-80-002
                    For 222/282/362 series it is A11U-0100-H12-08-002
                    Sent from my XT1254 using Tapatalk
                    • fixthecopier
                      ALIEN OVERLORD
                      • 4713
                      I had one yesterday doing this. Cleared the que and it worked fine.
