Requesting help from fellow techs on C650.
  • DadO
    • Dec 2007
    • 401
    Greeting all!
    I caught my self in a situation where i need to reset the fuzing/fixing unit counter of bizhub c650. I have pico fuze but it wont reset the counter. I placed it on the same place where minolta place it, that is under the fuzing unite.
    I looked for firmware on infohub but couldn't find any info on this issue only bug fixes. what firmware is it and witch hex switch.
    THX ahead
  • emujo
    • Jun 2009
    • 3009
    Re: Requesting help from fellow techs on C650.
    That's all there is to it...when PRCB sees new fuse it resets counter and blows fuse. You are either using the incorrect fuse, or your PRCB is damaged. You can install the PPLM mods and hide the life messages...Search this site for PPLM for info. EMujo
    • DadO
      • Dec 2007
      • 401
      I'm using same pico fuze (80miliamps) used for c353 series. Correct?
      • emujo
        • Jun 2009
        • 3009
        I have no idea...we put the PPLM mods in or replace the fuser, so I have never had to deal with replacing the fuses...I do remember that it is a slow-blo fuse Emujo
        • DadO
          • Dec 2007
          • 401
          Ok just another bad day after reseting the fuzing unite counter, machine comes in redy state and machine receive print ( or copy) job and says "print stop" under the job list. It stops there...doing nothing.
          I saw the HDD was set to "unset" so i switched to "instaled" and same goes whit fax kit.I switched it to fax circuit board 1(on)
          Cant do test print from service mode. The start key is red. Stabilization is no go too
          No jams and no Error CODES! wtf?
          help
            • 14521
            Are there any P codes on the display? I don't think it will reset if there are active P codes
            • emujo
              • Jun 2009
              • 3009
              Print stop means that some consumable has reached the end of life..Until it's reset or replaced you will not get any copy/prints. Under service mode/enhanced security there is a life stop setting, you can disable this to get a certain amount of copies out, but unless you turn on the PPLM this will only work for a short time. Emujo
              • DadO
                • Dec 2007
                • 401
                Enhanced security did the trick. Machine is working. Problem is none of IU's have come to end of life nor did transfer belt unite.....thats whats puzzling me.
                Thx emujo on extended help! (better then official minolta support )
                • emujo
                  • Jun 2009
                  • 3009
                  Those guys.....
                  Me: I have a customer with jamming from tray 3
                  Them: Replace Main Board
                  Me: I have a customer that has poor yellow laydown
                  Me: I have a customer that certain print jobs fail
                  Them: Update firmware, then replace Main Board
                  Seriously, they do provide a lot of help, but they don't seem to realize just how much a Main Control Board costs...Emujo
                  • methogod
                    • Dec 2008
                    • 917
                    they are pico slo blow fuses (green)
                    1/16A Little Fuse
                    Here is a link
                    http://www.ebay.com/itm/20-pcs-Littelfuse-1-16A-62-5mA-125V-Green-Pico-Fuse-Picofuse-/151743481393
