Biz Hub 654
  • antone
    • Oct 2014
    • 344
    Biz Hub 654
    Error 9401 lamb...anything to add ...not sure on parts!
    • 14820
    • splblazer91
      • Jul 2014
      • 204
      Re: Biz Hub 654
      Replace CCD assy. This is a common issue. Good Luck getting one they are on BO so many of these are failing.
        • 23009
        Re: Biz Hub 654
        Sure, clean the white reference and optics. Then when that doesn't fix it, replace the CCD. I've seen a couple myself.
        Now explain to me about the lamb.
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          Re: Biz Hub 654
          here they are a controlled item - when ordered you're given the 3rd degree, have you tried this this and this first ? But generally are supplied in a timely fashion when answering yes, i know wtf I am doing.
          • antone
            • Oct 2014
            • 344
            Re: Biz Hub 654
            You have part number
            Sent from my SM-N920V using Tapatalk
