C3350
  • jonpaul
    • Jul 2014
    • 59
    C3350
    We are thinking of using the c3350 as a small desk top MFP, does anybody have an opinion on their relaibility and ease of service.Any infomation on them would be useful.
    Thank you
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Re: C3350
    I have 3 C3850FS machines in field. Your typical maint seems to be rather simple as most the new machines. Only issue I had was a bad gear in drive assy making horrible noise. Not to difficult but not that fun to replace. The Op Panel is a little bit different in the menu setup but nothing that isn't easy to use. Non business hours weekly timer seems to be on by default so be sure to turn that off.
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • rrrohan
      • Sep 2011
      • 1977
      Re: C3350
      More reliable than a C35. We recently used 3350 & 3380 to replace some C35 and its amazing how little problems they cause by comparison especially considering the engine is almost identical
      Sent from my SM-G900I using Tapatalk
      • vapesenberg
        • Sep 2015
        • 10
        Re: C3350
        Terrible machine, lots of bad SSD & MFPB's .
        Sent from my SM-N900V using Tapatalk
        • mo0651
          • 1054
          Re: C3350
          Great Machine..... If you desire a decoration to put in corner and hold down carpet. DO NOT make copies with it!!!!
          • andyf424
            • Jun 2013
            • 126
            Re: C3350
            I don't like them but my boss says I'm a whiner...
            • mo0651
              • 1054
              Re: C3350
              I think we have sold 4... had to update firmware on all for stooooopid stuff. Most died during or right after. Enjoy!!!
              If I had too, Get any extended warranty with it!!!
                • 23008
                Re: C3350
                Think of it as an amalgamation of the mechanical reliability of Lexmark, and the mind bending firmware bugs of Konica Minolta.
                • occus
                  • 337
                  Re: C3350
                  Like the other Konica Minolta A4 Format machines... poor quality.
                  -Really bad print and copy quality
                  -transferbeld problems
                  -jam problems
                  -dont uprade the firmware
                  +cheap in toner and imaging units.
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    Re: C3350
                    don't agree with not updating the firmware, the original firmware is absolutely terrible. The latest firmware it a lot more stable.
                    we have 1 -200 in the field presently.
                    number 1 fault is touch panels failing - and they're costly. None of the replaced ones have failed again though.
                    Jams caused by careless endusers are indeed an issue.
                    environments with rough end users will see the plastic clip pop off the transfer belt retraction drive shaft - removing the jammed belt will be frightening for the uninitiated. It's actually pretty easy when you know what to do.
                    failing mfp boards, imaging units and other issues are no where near as common but do happen.
                    Print quality is crap compared to the full size machines, be under no illusion your getting the same print quality because your not.
                    • copyrooks
                      • Oct 2013
                      • 209
                      Re: C3350
                      I would say decent but not good. I've seen brand new fusers wrinkle paper, paper exit roller issues, control panel issues, slow machine. I would say reminds me of a grown up C35 with new issues.
                      • JR2ALTA
                        • Feb 2010
                        • 2033
                        Re: C3350
                        yes wrinking! and the warranty is apparently only 3 months
                        • wseyller
                          • Sep 2012
                          • 1129
                          Re: C3350
                          Have many in the field. Haven't seen many hardware issues. Replaced a control panel once. Did have two fusers recently that are wrinkling paper. Last one only used 30% of fuser.
                          Firmware is a pain in the ass to me. There is 3 different firmware to flash. Controller, sub controller, and engine.
                          If you do any embedded papercut solution they can be a pain to work with.
                          No where near as bad as the C35
                          Sent from my XT1254 using Tapatalk
                          • Kidaver
                            Ghoulscout
                            • Apr 2011
                            • 912
                            Re: C3350
                            My Sales Manager did bring up a point that it takes 7 steps to print out a meter read on these and he hates the idea of customers going thru that many steps to get to it. Unless I'm missing something is there an easier way to print out the meter reads on the models with this smaller control panel?
                            • rrrohan
                              • Sep 2011
                              • 1977
                              Re: C3350
                              Don't worry explaining Meyer page print outs to customer. You'll be there every month anyway
