Bizhub C454E Poor black density
  • axdexter
    • Jun 2025
    Hello. I have a C454E with around 60,000 copies. The black density is poor and streaky,
    almost like a bad drum. If you run halftones with any othercolor they are fine. Just black
    is bad. I swapped the drum and developer units, transfer belt and roller,updated firmware
    , swapped memory (never know), and the problem is still there. You can streaks in the copy
    count sheet, that are in opposite direction of the paper feed. I have an hv board ordered,
    along with a mfp board. Just looking for any suggestions.
    Thank for any help
    • 22999
    Re: Bizhub C454E Poor black density
    At the very least I would have calibrated the machine first. =^..^=
    • matthewr88
      • Jul 2015
      • 28
      looks like drum charge when the machines trying to do the full tones
      HV board is my first thought
      Can you fix it........we can fix anything its just how many parts do u wanna pay for
      • axdexter
        I thought it may have been the Hv unit too. It will be in tomorrow and I will find out.
        Thank you for the help
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          also check the black laser window hasn't been scratched the hell out of with spilled developer and cleaning wand.
          rookie mistake if it has...
          • axdexter
            Originally posted by EarthKmTech
            also check the black laser window hasn't been ground down with spilled developer and cleaning wand.
            I pulled the print head, it was spotless. No leaking developer units, and not a drop of dv anywhere. Of course opening a ticket
            "check firmware, replace memory, than mfp board!". I dont think its a supply problem, I swapped drums around (swapping chip also),
            before replacing the black drum and developer unit.
            Checked Tech rep mode > State Confirmation > Table Number
            All voltages are with a few volts of each other other than the black being 10v higher than the color.
            Vdc - Developer Bias around for black was 368
            Vg - Grid Voltage around 478
            I will replace the hv unit tomorrow
