c5501
  • CrapAimer
    • 296
    c5501
    Hi All
    have a problem with a C5501 It has a double image, have changed the fuser belt and roller also the transfer cleaning unit, it is always in the same position, any help appreciated
    George
  • habik
    • 2013
    Re: c5501
    When you print A3 multiples does it move on the page with same distance or over to next page.
    Or
    Is it spot on the same place every print?
    Also what are the measurements between the images?
    Firmwares HERE
    • CrapAimer
      • 296
      Re: c5501
      Hi
      On A3 the first half of the copy is coming out on the second bit if that makes sense. if I was copying 2 a4's on to A3 the first a4's image would be on the second bit.
      George
      • Mick01
        • Nov 2012
        • 362
        Re: c5501
        Hi,
        All colours or just one??
        You haven't by chance left the orange screws inside the drum? this wil cause your issue.
        If you stop the paper before it enters the fusing unit does the double image issue appear?
        Hope this helps
          • 23010
          Re: c5501
          If you can get a measurement between intervals and specific colors affected, I can give you a more specific answer. So far it could still be one or more of the drums, one or more of the developing units, or fuser. I like "orange screws" thing. I've found that a few times myself. =^..^=
          • CrapAimer
            • 296
            Re: c5501
            Many thanks for the replies, it was the orange screws all sorted
            George
