Bizhub C550 no response
  • andris
    • Oct 2015
    • 12
    Hi.
    I have konica minolta bizhub c550.
    Machine is turning on but no response from touch, keyboard.
    can anyone help with that problem?
    or.. where can i download firmware tool, firmware iso?
  • femaster
    • May 2011
    • 1519
    Re: Bizhub C550 no response
    Sounds like a bad stick of RAM. Try switching the 2 sticks around. If the machine doesn't boot at all after that, then you have confirmed that one of the sticks are bad. Then the fun of trying to figure out which one it is, or just replace both.
    • andris
      • Oct 2015
      • 12
      hi.i forgot to tell that here is one problem yet..
      sometimes after machine startup error message with code c-d403 appear..
      • femaster
        • May 2011
        • 1519
        I'd still give the RAM swap a try, but that error points to an issue with the MFP board. Re-seat the connections of all wires, etc. And see what happens.
        Sent from my XT1254 using Tapatalk
        • andris
          • Oct 2015
          • 12
          OK.thanks for advice
          • andris
            • Oct 2015
            • 12
            hi. i switched RAM and copier does not boot up. with one of RAM copier does not boot at all
            with other i can see only sandglass
            • andris
              • Oct 2015
              • 12
              I raplaced RAM.. copier start up, keys are working
              but now is another error 'insert imaging unit'
              where can be a problem?
              thanks
              • femaster
                • May 2011
                • 1519
                thanks
                I'm assuming all imaging units are in the copier? If so, I'm going to say that either one is not in all the way, or the contacts are dirty. Pull them out, clean up the contacts both on the image unit and inside the copier and see if that clears up that message. That would be the easiest potential fix anyway.
                • andris
                  • Oct 2015
                  • 12
                  Yes all imaging units are in the copier. a cleaned up contacts- no result
                  • andris
                    • Oct 2015
                    • 12
                    hi again
                    i have now C-2559 error pop up during warm up.
                    • Zackuth
                      • Aug 2009
                      • 448
                      That code means the cyan TCR sensor adjustment failure. You can try cleaning the sensor if that doesn't work you'll have to replace the cyan imaging unit.
                      If at first you don't succeed, redefine success
                      • andris
                        • Oct 2015
                        • 12
                        thanks for advice.
                        and how about firmware.maybe wrong firmware is installed?
                        before error with RAM etc all was OK
                        • andris
                          • Oct 2015
                          • 12
                          i swap cyan an magenta TCR sensor..and nothing changed- error c2559
