BH552 jams second sheet from tray 1 code 11-01
  • Desert Rat
    • May 2008
    • 1089
    [Jamming] BH552 jams second sheet from tray 1 code 11-01
    Someone has had to see this; the machine runs fine from trays 2,3 & 4.
    Tray one will feed 1 sheet through without a jam or code. But ask for
    2 or more and the second sheet stops not in but at the registration roller.
    When I first started this call, trays 1 & 2 were empty according to the control panel. But there
    was paper in both. I pulled the trays thinking to remove a sheet of paper but there was none.
    Turns out the lever in the back that lowers the pick up rollers was not moving up. I cleaned
    the face of the lever and the spot on the tray then they both started working again.
    I have used the sensor check in svc mode to check the sensors and they all ring true.
    I pulled both feed assemblies and cleaned the sensors anyway and cleaned the rollers.
    I checked the one ways and they seem to only go one way, but I know they can be intermittent.
    Last December I was here and wrote in the log that I swapped the upper and lower oneway on
    the shaft. Not the ones by the rollers.
    This does not seem like a jam from a oneway fail. And it doesn't make sense that the electro-magnetic
    clutch would cause this type of jam.
    I did check the sensor under the lint trap. It was still clean from the last time I checked it about 10 days ago.
    Can the tray 1 and tray 2 feed assemblies be swapped?
    Any suggestions?
    DR
  • allan
    RTFM!!
    • 5462
    Re: BH552 jams second sheet from tray 1 code 11-01
    Looking at the manual the trays should be the same.
    Could still be the feeder?
    Whatever
      • 23009
      I'd start with clutches. =^..^=
      • allan
        RTFM!!
        • 5462
        Those you can change out. CL1 and CL2 from tray one and two are the same.
        If your fault moves from tray 1 BC would be correct.
        Whatever
        • Desert Rat
          • May 2008
          • 1089
          I guess I should have swapped the clutches or the feed assemblies the last time I was there.
          I'll do that next time out.
          DR
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            had this before, replaced everything still didnt work.
            replaced feed unit, problem solved.
            Still nfi what it was.
            • allan
              RTFM!!
              • 5462
              DR
              The feed assy's for 1 and 2 is not the same.
              Whatever
              • Desert Rat
                • May 2008
                • 1089
                Well, I can at least swap the clutches for grins and giggles. I wonder about the contacts for the feed assy and where it
                connects. May be a cracked connector? Or bent pin?
                I have to check these things anyway just to be through.
                I thought I saw an adjustment in the book about paper spacing.
                I think I'll have a look at that.
                EarthKmTech, I know your solution worked. I have been down that road with other models.
                Like you, I want to know what in hell is broken?
                DR
