Couple of questions about internal RIPs?
  • dagoof
    Still learning...
    • 220
    I'm working with an IC-601 right now, but my question should apply to all internal RIPS - once you've sent the job through to the RIP, how do you make adjustments from the RIP/machine end? The IC-601 doesn't seem to ouput to an operating system and, whilst I can view the job details from the machine's touch-screen, I can seem to find adjustments.
    Can anyone advise?
  • kalindd
    • Jun 2008
    • 192
    Re: Couple of questions about internal RIPs?
    I assume that you send your jobs via print driver.
    On the print driver look for a tab "Workflow" from there you can choose a "Print mode" just choose Hold to main body and you'll get your job in the Hold queue, from there you can change most of the parameters.
    If you want to control your jobs in a way like Fiery Command Workstation does, you need to install Job Centro and send your jobs to "Hold to Image controller" or directly import them in Job centro.
    I hope that helps.
    • dagoof
      Still learning...
      • 220
      Thanks Kalindd, I am sending the jobs through to a c8000 from a PC (only had 2 drivers available, the PS and the XPS driver - using XPS driver as it has graphical interface).
      There's no workflow tab on this driver. I've got JobCentro installed, but without the ability the send to 'hold' I haven't figured out a way to do it from there
      • darry1322
        • Oct 2010
        • 817
        Not my area of expertise, but couldn't you create it as an LPR port and enter "hold" as the queue name?
        • dagoof
          Still learning...
          • 220
          Thanks Darry, just tried that but it outputs to print as usual...
          • Mick01
            • Nov 2012
            • 362
            HI,
            I dont fully understand your issue but I assume you want to be able to edit the properties of the job at the rip (page size/weight/tray/colour settings etc.)
            If you have Job Centro installed (which you must have), you can use this to import jobs directly into the IC-601 (has to be a PDF/PS file). You can then edit the properties of the job inside Job Centro (similar to command workstation with an EFI Rip.)
            Hope this helps
            • kalindd
              • Jun 2008
              • 192
              Can you connect to your RIP with Job Centro?
              If yes just choose -
              File-Import and then import your job. The job should appear in "image
              controller hold" if not or you get an error.
              Then you have to activate this feature.
              Go to [Utility] - [03 Administrator Setting] - [Controller] - [03
              System Setting] - [01 Software Switch Setting] and change Soft SW 28
              from 0 to 1.
              You should be able to import a job to Job centro.
              if not go to konicaminolta.eu - support and download the driver that looks like this ic601_c7000_pss_win_v20175_efigs_ja_kor_sc_tc_inst .zip
              Good luck
              • dagoof
                Still learning...
                • 220
                Thanks Kalindd, my driver is different (attached) - I take it the one you linked to will still be ok with the c8000?driver.jpg
                • kalindd
                  • Jun 2008
                  • 192
                  I don't know to be honest, just download the one for C8000.
                  • dagoof
                    Still learning...
                    • 220
                    Unfortunately Konica's site only had the option for this XPS driver or the Postscript one Kalindd...
                    • kalindd
                      • Jun 2008
                      • 192
                      Download the Postscript one
                      ic601_c8000_pss_win_v10175_jefgis_sc_tc_kor.zip (8757 KB)
                      • emujo
                        • Jun 2009
                        • 3009
                        The C8000 had 3 controller choices...emperon, Fiery and Creo....If you have only the IC601 then you are limited to printing only the way you currently are...You would need the Fiery or Creo to get the additional queues you need. Emujo
                        • dagoof
                          Still learning...
                          • 220
                          Yeah, looking that way Emujo
                          Kalindd - Well, getting some progress, part of the problem with the PS driver is I'm still using an old-ass version of pagemaker - when you place the driver in that, it has no graphical interface. If I output from a PDF, I can get it to output the the body/hold with your driver and got access to the controls.
                          Only problem I'm having now (not related to the driver), is really bad image quality (not print quality, more in terms of showing tons of image compression around JPGs). The machine had been taking auto-density read-outs automatically but was whipping them from the tray I was using and running charts over pre-printed stock, so not sure if that's what's done this?
                          • dagoof
                            Still learning...
                            • 220
                            If anyone could save me ripping what's left of my hair out, they'd be doing me a favour! Managed to get the friendlier XPS driver outputting to 'hold' and can edit some job functions at the machine screen end. Still having some trouble though:
                            1) In 'edit ticket', can't find a function to rotate 180 anywhere
                            2) again in 'edit ticket', I can't change the number of prints? E.g. if I end up 10 copies short, I can just key in a number to reprint without re-submitting from the original machine?
                            3) still getting this horrible compression around images
                            • kalindd
                              • Jun 2008
                              • 192
                              I'm sorry but can't help you.
                              I have never used XPS driver.
                              You won't find all those issue if you use postscript driver.
                              Cheers
