Couple of questions about internal RIPs?
  • dagoof
    Still learning...
    • 220
    #16
    Re: Couple of questions about internal RIPs?
    Thanks for all your help Kalindd - managed to find the rotate option, still looking for a way to edit copy numbers once on the body.
    You're right, the postscript image quality is fine, it's a bit of a pain as you can use preset options though.
    If anyone has used the XPS and can suggest anything for that, let me know
    • dagoof
      Still learning...
      • 220
      #17
      This machine is slowly killing me
      Spent 2 full days installing, uninstalling, reinstalling drivers. I did have a postscript driver fully operational at one point (including good quality colour prints and sending to 'hold' on the RIP), but the colour reproduction on the PS was really dull.
      After more fun, I'm back on the XPS driver. I also can't send it to hold. If I hit 'controller' on the machine screen, then Job List I can see the job is there but the status is "waiting" and it never progresses.
      Edit: Also have crazy quality issues with this driver, loads of compression showing around images. Just tried switching a problematic one from Dot1 to Line1 and it was perfect. Go to do next job on Line1 and it's got the same compression problem as Dot1 had before!
      Anyone got any ideas?
