Bizhub 227 error after firmware upgrade
  • wseyller
    • Sep 2012
    • 1129
    Just wanted to inform or see if anyone else has come across this. Not sure if it is an isolated incident.
    It has been seen when upgrading from G00-28 to G00-54 a trouble code occurs of c-6001. Only by downgrading back to G00-28 would the device work without error.
    Sent from my XT1254 using Tapatalk
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: Bizhub 227 error after firmware upgrade
    there was an email about 2 firmware updates that needed to be done to these machines. they had to be done in a certain order or an error would occur. I do not remember the details but will look for that email tomorrow.
    • Five
      • Jan 2022
      • 4
      Hi, I have a problem with the Bizhub 227.
      I uploaded the new G00-Y2 firmware and turned on the HDD menu in the service.
      Machine reset --- no HDD installed.(I didn't check)
      Now I have an external error, I cannot enter the service menu and I cannot upload the firmware again - (Download MFP -NG).
      Anyone have an idea how to revive the device?
      • tsbservice
        Field tech
        • 8064
        You should at least consult a tech before attempting such things...
        • Five
          • Jan 2022
          • 4
          Do you know how to help me?
          • tsbservice
            Field tech
            • 8064
            After you brick the machine it would be more difficult without attending it by certified tech.
            • Five
              • Jan 2022
              • 4
              Thank you very much for your answer. Unfortunately, nothing helped.
              Maybe someone else will know and tell me.
              • femaster
                • May 2011
                • 1526
                You can not do the firmware again because the hard drive is enabled in service mode and it doesn't exist. You need to go back into service mode and disable the hard drive. About the only error you should be getting is one that indicates the hard drive is bad (because it's not there), and that should not prevent you from getting into service mode. If the error screen is getting in the way, try pressing the "MENU" button.
                Of course, you could always just purchase the hard drive (and mount kit if needed) and install it into the copier. That should resolve that problem as well.
                • Five
                  • Jan 2022
                  • 4
                  Thank you for your response.
                  I connected the disk and nothing.
                  I did something else and it worked.
                  I connected a 128GB flash drive to the USB. (I tried to upload the firmware)
                  The device turned on and threw an error but I could now enter the service menu.
                  I turned off the disk in the system.
                  After restarting the machine, I uploaded the new firmware, turned on the HDD in the service menu, turned off and connected the HDD physically.
                  After switching on, it showed that the disk needs to be formatted. I did the format and restarted.
                  The device came back to life.
                  Thank you for your help.
