How to reset bizhub 552(black + white) after emptying toner waste container
  • axyun
    • Aug 2007
    • 1323
    Customer emptied waste container and installed but machine has waste toner box installation error. Install waste toner box and close all doors. Please help as in field and 10 minutes from customer office. Frank/ActionPhotocopy
  • antone
    • Oct 2014
    • 344
    Re: How to reset bizhub 552(black + white) after emptying toner waste container
    Make sure Window..is cleaned!On right side make sure tap is hitting senor...put paper if broken off...that's all
    • allan
      RTFM!!
      • 5459
      These customer will leave the waste box out all together if you block the sensor with paper. I have done that until i saw the damage that will do.
      Whatever
      • antone
        • Oct 2014
        • 344
        Block sensor with paper...put box in
        • axyun
          • Aug 2007
          • 1323
          If you are talking about where the window on waste toner box enter i just put paper there but nothing happens whe i close door. Same message stays.
          • axyun
            • Aug 2007
            • 1323
            Does the waste toner box life need to be reset on control panel?
            • allan
              RTFM!!
              • 5459
              No. This one is very simple. One sensor to check for toner overflow. and one to check if the box is set.
              Whatever
              • allan
                RTFM!!
                • 5459
                Oops and rotation sensor.
                That happened on the "e" range where the machine does not even stop if you remove the box. No detection at all.
                Whatever
                • vapesenberg
                  • Sep 2015
                  • 10
                  The correct solution is to Replace the box not empty it.
                  Sent from my SM-N900V using Tapatalk
                  • allan
                    RTFM!!
                    • 5459
                    Surely you can reuse them?
                    Whatever
                    • vapesenberg
                      • Sep 2015
                      • 10
                      Sure, just like you can you use after market toner; or poorly cut or humid paper; but there are consequences to your actions. You get what you pay for, cutting corners only leads to bigger issues down the road. In my 9yrs of experience it is Always better to do it right the first time then have to go back and re-do it. What is your time worth to you? Surely more than that inexpensive waste toner box....
                        • 22930
                        There are three ways that KM detects waste toner:
                        1) the window: There is no easy way to get to the window to clean it. If you get water in there you will end up with a disaster.
                        2) the flag: There is a flag that blocks a photointerrupter to identify the presence of the bottle. Customers routinely break this off.
                        3) the agitation sensor: If the waste toner agitator cannot rotate, you'll get a waste bottle indication. You need to be able to rotate the agitator manually.
                        Don't waste your time. Encourage the enduser to buy waste bottles. =^..^=
                        • axyun
                          • Aug 2007
                          • 1323
                          I saw the 2 sensors on the front left bottom of machine. The photointerruptor for the window and the one the flag that turns and engages sensor. I did not see a third which is probably why still same problem. Customer told me she emptied waste and had to do it 4 times as there was still toner in container. I am thinking customer prpbsly broke the flag for sensor that detects container though i missed the sensor. Is it front right side?
                          i can check the parts and service manual when i get back in morning. Not familiar with thus machine. Have done several calls on it. Thanks to all for your info and help. I will post results when call is finished. Frank
                          • allan
                            RTFM!!
                            • 5459
                            I have reused the same waste box on a C360 probably 15 times.
                            Imagine a landfill.
                            vs
                            Whatever
                            • axyun
                              • Aug 2007
                              • 1323
                              I only see 2 sensors over to the left. One is ps23 which I guess is the rotation sensor which sees the rotating flag at bottom of waste box. the other sensor is a few inches away and higher . it is ps54 which sees window on waste box. I did not see any other sensors. This the the black and white 552 NOT the color C552. Any additional help is appreciated very much. Frank
