Hi all,
Got a couple of questions about the C280 range of machines. I had a problem with one which when I saw what they were trying to tell me about was a fusing issue. The toner wasn't fusing to the paper and was causing a ghosting image where the toner was left on the fuser rollers. I changed the fuser with a one from another machine which worked for a couple of days but then did the same thing.
What I'd like to know is what should the two temps be? The temps I'm seeing are around 180c for the temp heat and 140 for temp pressure which I think are about right, what do you think?
Also have any of you seen this problem and found a different problem like voltage supply?
Im hoping it's just an old fuser which is also failing but any info from you guys would be useful.
thanks Paul.
thanks Paul.
