Konica C450 Restarts unexpectedly
  • parsmehregan
    • Jun 2012
    • 97
    Konica Minolta Bizhub C450
    When booting for first time in day, it works for about 1.5 hours , so after that it restarts even twice repeatedly.each time it passes all process including warm up screen ,Engine warm up and boot to the main menu. power green light and no problem with printing....but after a while the screen vanished and restarts. connecting to system through network (TCP) I suspicious of virus effecting the function of MFP .
    Any similar experience with konica? Any idea or solution to this matter would be appreciated.
  • Don N.
    • Nov 2011
    • 409
    Re: Konica C450 Restarts unexpectedly
    That would be the first time I've heard of a virus causing a reboot. More likely a corrupt print job or an IP conflict. I'm not familiar with c450 but what would you assume on a brand you're familiar with?
    Power supply, since its old and its failing after its warmed up for a while?
    Sent from my Nexus 5 using Tapatalk
    • antone
      • Oct 2014
      • 344
      Try disconnecting IT cable!!
        • 23010
        A dead or dying HDD will also give those symptoms. =^..^=
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          Having the power cable half hanging out the back of the machine will do this too - cant count how many times ive driven all the way out to a machine just to push the power cable the whole way in....
