C220 PC fax
    • 14629
    C220 PC fax
    I am putting a refurb C220 out and it has fax. When I fax from the DF the fax shows Company name and fax#. When I PC fax it shows only fax#. I have seen this before and have cleared fax settings in service mode and that has solved the problem. I'm not sure what else to do. Any help is appreciated.
    Thanks.
    • 23003
    Re: C220 PC fax
    That's because the PC fax TTI settings are stored in the sending PC. When you install the PC fax driver you must enter the TTI data, including the phone number and company name. =^..^=
      • 14629
      Re: C220 PC fax
      Thanks for the reply blackcat, but I have been through the driver and can't find anywhere to enter TTI information. I have installed many fax drivers and have never had to make adjustments to them. As stated before when I clear fax data in service mode it usually sends info properly, but not this time. I was just wanting to know if there is a setting on machine that I don't know about for transmitting sender's info.
        • 14629
        Re: C220 PC fax
        Did another fax clear in service mode and entered info at machine instead of using pagescope and all is working normally now.
