konica c280 transfer belt replacement
  • DOE
    • Mar 2010
    • 258
    is there a fuse that will reset transfer belt and are they the same as the c250 fuse. this is for a konica c280. i have never replaced a transfer belt, is there any videos that anyone knows about on how to remove it. i dont have a service manual for this machine. thanks
  • antone
    • Oct 2014
    • 344
    Re: konica c280 transfer belt replacement
    Remove rear right cover disconnect 2 connectors.....remove right door hinge cover 3 screws.....open right door registration unit....remove 2 screws ..unlock transfer belt
    • copier tech
      • 8172
      No fuse, you can simply reset it in service mode.
      Go to Counter, life, choose new release, highlight fuser, open the front door & press start (it should turn blue)
      • edcloss
        I believe on the c280 you reset it in service mode. Choose counter and then new release. Open the front door. Highlight transfer belt and then hit the start button.
        • DOE
          • Mar 2010
          • 258
          doesnt this take a special tool in order to do it this way?
          • copier tech
            • 8172
            No tools are needed, like I said you can simply reset the ITB & fuser counter in service mode.
            • DOE
              • Mar 2010
              • 258
              THANK YOU!!!!!
