bizhub 423 doc feed df 621 question
  • brent
    • Nov 2008
    • 1214
    I am going to get flack from this.. but I have adjusted back and forth. basically the image is shifting.. I am missing the leading edge of the copy as I use the document feeder.. I have went into area leadingedge adj and printer area paper feed direction adj. I am not making any progress
    so again.. when using the doc feeder the print is too close to the leading edge.. any suggestions anyone has for me?
    while using a document from the glass the image is fine
    I have looked in the df manual. but there is nothing there just mechanical adjustments
    thanks all
    brent
  • copyrooks
    • Oct 2013
    • 210
    Re: bizhub 423 doc feed df 621 question
    i think i know what you're talking about go to service mode, adf, original stop position. Forgive me if i misunderstood.
    • andyf424
      • Jun 2013
      • 126
      Check your DF-621 installation manual, adjusting your document stop position. You need the doc feeder test chart though.
      • khadimetareqat
        • Mar 2017
        • 35
        sir any one can give me test chart for adf adjustment
