bizhub 250 fs-508 removal
  • groovy
    • 179
    hi all,
    need to remove a fs-508 from a dead bh250 and i don't remember how to.
    Please help.
    Thanks in advance.
  • kingarthur
    • 1330
    Re: bizhub 250 fs-508 removal
    the quick way, open the door on finisher, then there's a hole around the middle near the bottom, screwdriver or other object in there , you should be able to slide finisher towards front of m/c, correct way, open door, remove panel hiding connectors, unplug all connectors, then remove either 4 or 6 screws holding the tray unit on, lift off tray section, then as above....
