Konica Minolta C364 Scan to Email Server Connection Error Intermitantly
  • copierwhisper
    • Mar 2013
    • 78
    [Misc] Konica Minolta C364 Scan to Email Server Connection Error Intermitantly
    I have a Konica Minolta C364 that at times gives a Serve Connection Error when scanning to email, from one attempt to the next it may or may not work. I did a data clear and reformatted the hard drive, reconfigured the scan to email settings and still the same thing, Server Connection Error or successful completion.
    Any thoughts?
  • copier tech
    • 8195
    Re: Konica Minolta C364 Scan to Email Server Connection Error Intermitantly
    Any thoughts?
    First try updatng the firmware.
    What account are you using for SMTP?
    โ€‹
    • Gaffers01
      • May 2011
      • 335
      Yes I have had this before on a couple of machines in that range, a few things to try are:
      1. Make sure machine and admin email both have the same domain name.
      2. Change the time out setting to 120.
      3. Under "Network Settings" look for SSDP Protocal and disable it.
      4. Try using SMTP IP address instead of the Host name.
      5. Turn OFF IPV6 protocal.
      Hope this helps.
      • peter42
        • Jan 2012
        • 110
        IPv6 disable is also my tip.
        but use for machine adress and admin adress the same allowed mailadress for the network.
        I dont know why but some of the bizhubs use the admin-adress as sender.
        If all the hints here doesnt help:
        let check if the Mailserver has a rule for spam delivery set.
        If a lot of company-members are using the mail-scan, it is possible that the servers denies mail-relaying.
        greetings peter
        • SmellsHot
          Head Tech
          • 512
          That's fixed all of my intermittent issues.....
          Everyone has the right to be stupid. Some people just abuse this privelage more than others
          • wseyller
            • Sep 2012
            • 1129
            This thread was useful to me. Had a C284e with gmail stop working. Tried new account and new firmware. Could ping hostname ok. Tried ssl or tls. Final trick that worked was turning off ipv6.
            Sent from my XT1254 using Tapatalk
            • ni311
              • May 2008
              • 658
              Is it a free SMTP mail server (like gmail) or a paid service?
              Konica Minolta Error Codes - Explanations and Solutions
