konica c35 jam codes
  • DOE
    • Mar 2010
    • 258
    i dont have a c35 service manual. could someone tell me how to turn on jam codes. copier says jam but no jam to be found. cleaned sensor below the transfer roller checked others over and all looks well. have took it all apart and checked over and still says jam but doesnt give code. thanks arrow points to side door.
  • allan
    RTFM!!
    • 5462
    Re: konica c35 jam codes
    Is your paper leaving the tray?
    Print out an event log in service mode. Its under print menu.
    This machine does not have the traditional jam codes, but it will count the jams per section.
    Let us know what section.
    Whatever
    • tech51
      • 846
      I'm with Allen on this one.
      Customers nearly always report jamming but no paper in the side to clear.
      I normally put a mark on the feed roller to make sure it's rotating.
      If not it's generally the feed clutch at the back of the machine.
      If it's rotating then it's usually the feed roller and double feed roller that are worn.
      Replace them as a pair or it will still jam.
      Also check that the silver guide plate and mylar that sit under the feed roller are intact and still stuck on correctly.
      Hope this helps.
      • DOE
        • Mar 2010
        • 258
        Hope this helps.
        copier says jam right away and will not let you make a copy. has a arrow pointing to side door. i have taken copier apart and there are no jams. cleaned all sensors but still says its jammed.
        • allan
          RTFM!!
          • 5462
          Change all the feed components in the tray and both clutches at the back of the machine.
          In one case the entire paper tray fixed the problem. It's a known issue on these C35 machines.
          Whatever
          • DOE
            • Mar 2010
            • 258
            • habik
              • 2013
              You have to remove the back covers and work from there.
              Firmwares HERE
              • tech51
                • 846
                Which actuators/sensors did you change?
                It certainly seems like you have a sticking actuator somewhere.
                A tech of mine had the actuator in the duplex path stick causing the fault you describe and that was on a new assembly straight out of the box.
                The actuator above the transfer roller and the exit actuator can stick also causing this.
                Failing that you may have a wiring or board fault.
                Anything is possible on these little monsters!
                • Synthohol
                  Certified Konica Expert
                  • 5824
                  you can try this guide, usually i find the one way bearing clutch slips on the shaft. burnish the shaft with a scotch brite pad or emery cloth same direction as the shaft and soak the clutch bearing with alcohol.
                  • habik
                    • 2013
                    I've had success with modified mylar on separation I made. When I go there next, I'll take a picture.
                    Firmwares HERE
