After machine sits no rhyme or reason how long sometimes from 3 minutes upwards to half an hour will say it has a jam at finisher entrance. Open finisher nothing close will say jam in fuser area. Open it nothing resets jam. Will post Pics of what it says asap. Almost seems heat related
Bizhub 601 false jams in finisher?
Tags: None
Re: Bizhub 601 false jams in finisher?
Clean all 5 punch unit sensors. Check LED'S on FN control board.
Sent from my SM-N900V using Tapatalk -
Jam codes? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
I was going to disconnect the finisher to test if it went away but ran out of time. Short video of what it does after I gets a false an can reset it buy opening finisher then machine an pulling transport/fuser section out.https://goo.gl/photos/Nkdsxsc4aLDpqFkc6Comment
There is a sticky actuator damper in the exit section on the machine, remove the small sponge pad.
Remove the side cover and the exit section 5 screws and a connector look for the sensor and see if it sticks.WhateverComment
Seriously!? Are you for real? Trying to get your post count up for some reason?Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.Comment
Back on machine. Has no hole punch. Did disconecting fs-925 finisher problem goes away. Can't find any thing causing this...Comment
