Bizhub C454e deleting driver
  • copier tech
    • 8131
    [Misc] Bizhub C454e deleting driver
    Hi all,
    I have a weird one here, customer has a c454e installed on their print server they are also using equitrac, it was all set up a couple of months ago & has been running fine.
    However now each morning when they log on they find the printer driver has been deleted on each users machine, their IT dept reinstalls it, all is fine until the next day when they log on in the morning & it has disappeared again.
    This is how the customer has reported the fault, they are a very long distance away so am yet to visit the site, however am at a loss as to what could cause this, surely it must be a Windows issue? not the copier side?
    Any advice would be appreciated.
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Re: Bizhub C454e deleting driver
    It would almost have to be a Windows thing. What version of Windows are they using? There is no way a machine can delete drivers from a PC.
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
    • emujo
      • Jun 2009
      • 3009
      How were the drivers added to each PC? Group Policy, add networked shared printer? Is this a terminal services (thin client) setup? Sounds like there may be some kind of policy in place that restricts the amount of time user are able to use the shared device. If you set up a local version of the print driver and add the EQ desktop client (not normally needed) will the drivers remain? Emujo
      • allan
        RTFM!!
        • 5462
        could be that the configuration gets frozen and loose all gained changes with a scheduled restart.
        It's a good way to protect public computers.
        Whatever
