bizhub PRESS 1052 saddle stitcher grippers
    • 23009
    I've heard a rumor that there is a new style gripper for the SD-510 saddle stitcher. Or perhaps it's it's a retrofit from another model saddle stitcher. Does anybody have details, like maybe a part number?
    On thicker booklets it's fine, but on thinner booklets of 2 or 3 pages the paper slips out of the grippers and the staples end up off center, and the fold equally off center. I've already added an additional 1/2 wrap to the spring on each of the grippers. The rumor I heard was there were grippers with rubber tips, for better grippage. =^..^=
  • iceman490
    • May 2014
    • 46
    Re: bizhub PRESS 1052 saddle stitcher grippers
    Never heard of a new gripper for this model. I just fought one throwing jams and grinding. I have seen there are foam blocks on the folding blade that get caught in the fold and cause mis folding.
    Sent from my SM-G920V using Tapatalk
      • 23009
      Those have been replaced on this finisher. My customer managed to bend the folding knife during a jam removal. I am perplexed exactly how it would happen. During the part change, I noticed the foam pads with mylars on the new part that were completely absent from the old knife. All but a little residual adhesive and a few scraps of mylar, that is. =^..^=
        • 23009
        bump. Grippers anybody?
        • beetle73
          • Dec 2010
          • 44
          The fix for this issue is to increase the thickness of the gripper itself.
          I took a small piece of rubber and glued one to both grippers. ( separator pad from document feeder works well)
          Problem solved. I believe there will be a tech tip.
          Good Luck!
            • 23009
            I'll give it a try. Thanks beetle.
            • yakyitz
              • 245
              This is the part# A10D412901 As per bulletin KBA01500850
                • 23009
                Thanks Yak. =^..^=
