Konica Lockups
  • bobbyb
    • Aug 2025
    Konica Lockups
    Hi all -
    18 leased machines, 5 of which are locking up. It is very hard to reproduce the lockups. Reset machine, plug in ethernet cable and the panel will lockup within minutes. You cannot access the copier via the browser either. Occasionally a random error will appear that's very general "Internal Error, machine restarting". Machines are all on the same network, some on the same subnet. Updated drivers, fax is not the cause. Konica reps say that they have checked the RAM and HD and diagnostics report OK. The same 5 machines were having the same issue approx 3 months ago and a firmware update appeared to have fixed it. One machine is brand new and having the issue. Other symptoms are: 1. Random jobs that say "Deleted due to error" 2. Staff reports that the machine is offline 3. Machine still pingable when locked up
    Has anyone experienced the touchscreen locking up and freezing? I have searched and see that people have had it freeze on the logo but that does not happen for me. It boots, prepares the scanning and copying then locks up 2-4 minutes after. Sometimes, It will work for hours! Konica has been zero help for this and blames our network. That's OK but they won't tell me whats causing their device to lockup!
    Thanks for any help.
  • T_foot2
    • Nov 2011
    • 22
    Re: Konica Lockups
    Just had the same problem with a 754.
    This is from our tech support:
    Analysis:
    Disabling IPv6 on the MFP might help as wel
      • 23010
      Re: Konica Lockups
      Analysis:
      Out of curiosity: Can this port 50001 be blocked by a managed switch or router? =^..^=
      • splblazer91
        • Jul 2014
        • 204
        Re: Konica Lockups
        Originally posted by bobbyb
        Hi all -
        Check your network speeds in admin mode and make sure they are set to Auto negotiate up 1gb p\s
        • allan
          RTFM!!
          • 5462
          Re: Konica Lockups
          I think you can change the port number.
          Whatever
          • Gaffers01
            • May 2011
            • 335
            Re: Konica Lockups
            Ive had the same problem with 3 machines on the same network at a customers,
            I tried all sort of settings like others have mentioned but it ended up being a faulty network switch,
            There network people were adament it wasnt faulty until I got there boss on my side and he told them just to try it.
            Havent been back for 6 months (they were c284e)
