Bizhub C451 covers sheet with a heavy magenta tint
  • Capodastra
    • May 2012
    • 58
    Can anyone give me some pointers here . . .
    This started out of the blue. I had printed a few sheets through the Fiery Command Workstation earlier without any problems and about an hour later this starts happening.
    I have changed the Magenta drum as I thought it might be that but, it still happens.
    Any help please.
    Regards
    Barney
  • allan
    RTFM!!
    • 5462
    Re: Bizhub C451 covers sheet with a heavy magenta tint
    post a sample. Could be the HV and or some other things.
    Whatever
    • minimerlin
      • 851
      Any help please.
      Regards
      Barney
      Try blocking the magenta laserpath in one area with a small strip of paper. If you get a blank area on the copy/print it is the laser head!
      Please do not PM me without asking first.
      • Albonline
        • Sep 2008
        • 1144
        edge to edge would be laser. if there are deletions around the outside hv
        • Capodastra
          • May 2012
          • 58
          Here is the image of one sheet.
          Help please . . . desperate now. BD(
          • minimerlin
            • 851
            [ATTACH=CONFIG]31895[/ATTACH]
            Have you tried my previous suggestion as an aid to fault finding? Last time I saw that problem it was the laser!
            • Capodastra
              • May 2012
              • 58
              I am an end user and do not know how to do that.
              • Elmo
                • Feb 2010
                • 541
                Then you need to call a qualified tech who does know how to do that !!!
                I Used To Live To Fix Things Now i Fix Things To Live
                • folukems
                  • Nov 2011
                  • 11
                  can you pls attached the image for proper advice
                  bcos if it started with cyan nd jump to magenta its likely a static charge is build up somewhere
                  Any help please.
                  Regards
                  Barney
                  • Capodastra
                    • May 2012
                    • 58
                    Sorry, but you misread me. When I say it started "out of the blue" what I mean is it started suddenly, not gradually. That is an old English saying.
                    The image is in a previous post.
                    BD)
                    • Capodastra
                      • May 2012
                      • 58
                      Elmo, though I appreciate your help, that is NOT helpful - to call a tech in the UK is mega expensive, and I am a man working from his garage office.
                      BD((
                      • Elmo
                        • Feb 2010
                        • 541
                        BD((
                        ok so you are just happy for people to give you their knowledge for free
                        most of the advise you will be given on this site is for techs as it is a tech site
                        the advise about trouble shooting is to help determine the problem with the machine
                        if you cannot perform some of these basic tasks, then it makes the job of helping you very difficult
                        also you can cause more damage by not knowing what you are doing
                        that is why i advise you to call a qualified tech
                        if it was a simple fix then someone would have told you what to do
                        the fault looks most likely to be the magenta laser unit
                        the advise given is to help determine that it is definatley that replacing it is not an end user job
                        • Capodastra
                          • May 2012
                          • 58
                          OOPS sorry Elmo if that was offensive, was not meant to be, did not know that this was a board only for techs, thought it was was for any business that had a machine too.
                          Sometimes in my situation you have to do stuff tyourself. Service contracts are immense for a small one-man business, so you have to mend and make do. When something goes wrong just a pointer would help.
                          As in this case, after the post from Minimerlin I made contact with an old friend and colleague who used to be a service engineer for Konica Minolta. Now works for someone else, and fortunately for me he was in a town near me today and has come and checked the machine, his first thought was that a HV board had gone (he said there were two and he could not be sure which one) but, taking note of Mnimerlin's suggestion he blocked the path of the magenta laser and it worked - half the sheet was ok the other have flooded with magenta. He then took the laser unit out to see if he could do anything and as it was 'sealed' he said I would have to get another. He re-seated the unit, and checked again, and it worked perfectly normally.
                          So I (we) know for the future if it happens again.
                          I understand the issue about making matters worse as "end-user" meddling with something I am not sure of, but surely knowledge shared on this board has to be a blessing to those in trouble!! I am now in my sixties, and, sadly for me, have to still work, I have been in the print trade since a boy as an indentured apprentice letterpress compositor and have experienced immense changes in the industry changing to litho and then retraining through the paste up process, then having to learn the technicalities of camera operation to shoot negs for platemaking; platemaking itself and then film planning to final film as well as to foils for platemaking; the introduction of Macs (for me from the early 90s) changing the industry amazingly; investing heavily in imagesetters and drum scanners for transparencies; finally into digital printing.
                          This amounts to many years of professional experience and I would never begrudge anyone the benefit of those years if it helps to get them put of trouble. Knowledge is treasure, and some keep the treasure to themselves reluctant to help others.
                          My apologies if I have offended you, but surely, your help on this board should be without prejudice? I do not get that from your replies.
                          • allan
                            RTFM!!
                            • 5462
                            Its the other way around.
                            Whatever
                            • Elmo
                              • Feb 2010
                              • 541
                              No offence was taken
                              just advise given
                              and im happy you got a tech in who got you sorted
                              it is always helpful to give a little background info so people know what level of help to give
                              there are a lot of end users who come on the forum expecting help for free
                              and then when given advice
                              don't listen then complain that people here are not helpful
                              this is a free site the wonderful people who contribute do so out of the goodness of there own heart
