defect in magenta imaging
  • rodrigo neres
    • Feb 2012
    • 25
    [Electrical] defect in magenta imaging
    hello doctors
    I have a Minolta Konica BIZHUB C6501 presenting a defect in the generation of the image. (Only 100 % magenta color ) .
    already changed belt / Corona / drum DU104 / new developer and reversed laser to try to isolate . (image attached)
    (several white spots on the entire sheet).
    the adjustment process , changed the values ​​of the first transfer to -46 and -50 (minimum and maximum) all collors / second transfer and performed automatic gamma adjustment.
    machine prints usually does not generate error.
    I appreciate any hint to try to isolate the fault.
    Grateful
  • Gaffers01
    • May 2011
    • 335
    Re: defect in magenta imaging
    Hi,
    cant see a lot on your image, are you using genuine toner?
    Does it do the same on different stocks?
    Could be the fuser unit causing it maybe not getting hot enough as 100% coverage.
    • allan
      RTFM!!
      • 5462
      If that drum does not receive charge you could get that problem. Could be small overlooked problem or the HV supply is not giving charge on magenta.
      Whatever
      • rodrigo neres
        • Feb 2012
        • 25
        Good evening,
        thank return.
        Toner, drum and developer are genuine.
        It should really be a problem in the HV boards. tomorrow I will be taking another to test the machine. ai inform what happened.
        hugs
          • 23010
          How did you make this image?
          Is it a sky shot with the machine set to single color magenta? Sky shots often do not have very even fill, as a result of overhead lighting. See: http://www.copytechnet.com/forums/ca...-sky-shot.html
          Is it a copy?
          Is it a print of a PDF?
          Is it an internal test pattern?
          Try this PDF original:
          • tulintron
            • Jul 2014
            • 668
            Originally posted by rodrigo neres
            Good evening,
            thank return.
            hugs
