I have a C552 that has a ic-412 fiery. Fiery does not stay on. when you turn on power button it starts to come up, then shuts down, no error codes??? Ideas??
biz hub c552 fiery issue
Re: biz hub c552 fiery issue
I would be looking at the CPU fan or memory. The fans get so clogged up they become ineffective, if the processor has gone that will not be a cheap fix. -
That looks, like bootloader from fiery-HD is damaged.
Give a new Sytemsoftware for the Fiery a try. It will format
the whole disk before loading the real Systemsoftware on it.
If that not helps or dont run to complete, change HD and
reload systemsoftware again.
PS, what is the digitdisplay at fiery showing?Comment
