Bizhub 363 9901 jam
  • jwrycza
    Office Systems Expert
    • Sep 2013
    • 88
    Bizhub 363 9901 jam
    This machine has a PC-409 and that is where my problem lies. It will only jam from this tray. The first sheet gets about half way through the registration assembly, the page behind it just stops coming out of the drawer but, it seems to continue to drive the feed portion so it z-folds the back half of the paper. The clutches and rollers from the feed head have been replaced, the reg roller bushing have been cleaned and clutch has been replaced, Firmware has been updated to G00-D6. There is no info in the service manual and nothing on the knowledge base. Any help would be appreciated!
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Re: Bizhub 363 9901 jam
    Worn sync roller bushings or sync rollers where the bushings run would be good possibility.
    Got this from the solutions on my KonicaMinolta.com
    Workaround/Fix PROBABLE CAUSES:1. Soiled/faulty PS11*(Tray*1*paper*feed*sensor)*or*PS21*(Tray*2*pa per*feed*sensor)Test*PS11*and*PS21*in*Sensor*monit or*1.*If*not*changing*state,*clean*the*reflector*p ad*or*replace*theaffected*sensor*(p/n*A0ED*M501*00).Notes:1.*Only*bizhub*423*has*these *two*sensors.*They*are*used*to*control*the*gap*bet ween*each*sheet*of paper*in*order*to*maintain*the*fast*copy*speed.
    Edit: Copied and pasted from solutions PDF. No clue why it added stars between words. Not going to edit them out because it would take too long.
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
    • CopyJunkie
      • Oct 2012
      • 28
      I have had the Transport Motor (M1) fail causing a mistiming in paper transport and indicate a J-9901. Think I have seen this on three different machines. Part number is A1UDM10000. Hope this helps.
      NOTES ON HOW TO USE THE FAX MACHINE.
      1. Get into your DeLorean (or your TARDIS) and go back to 1990.
      2. Place papers in the machine - Face Down.
      3. DO NOT dial 9
      4.
      Rejoin the rest of modern civilization.
      • Hansoon
        • Sep 2007
        • 3374
        I had one failing completely.
        Hans
        • allan
          RTFM!!
          • 5462
          i had one where the transport sensor (photo reflective) was soiled with paper dust.
          Whatever
          • CopyJunkie
            • Oct 2012
            • 28
            Photo Reflective sensor is only on the 423. That transport sensor is a Photo Interrupter on the 363.
            3. DO NOT dial 9
            4.
