K drum for c224
  • jonpaul
    • Jul 2014
    • 59
    K drum for c224
    We were curious to know if anyone has used a black drum as a colour one in the C224 series ?.We have done it with the 220series without out any problems and a big saving.Also upgraded firmware on a C203 and it threw C-C164 anybody come across this. Thanks all
  • MDR24
    • Apr 2013
    • 64
    Re: K drum for c224
    Yes it does work for the C224 series also. We order the black drumd and chip them with the CMY chips when necessary.
    • Tech Helpdesk
      • Jul 2015
      • 112
      Re: K drum for c224
      Hi there,
      We also use the black drums in the colour sockets and using colour chips to reset the counters. We also reset the developer units and we suffer no developer depletion and we run the units to twice their life. Massive savings all round !!!!!!!
      • Moza
        • 232
        Re: K drum for c224
        The same chip can be used for all of the following devices and pretty much halves your cost of the colour drum
        Bizhub C224
        Bizhub C224e
        Bizhub C258
        Bizhub C284
        Bizhub C284e
        Bizhub C308
        Bizhub C364
        Bizhub C364e
        Bizhub C368
        Bizhub C454
        Bizhub C454e
        Bizhub C554
        Bizhub C554e
        • habik
          • 2013
          Re: K drum for c224
          Drums. Yes
          CC164 if I remember correctly from TOMH wrong firmware loaded.
          Sent from my iDon't believe in marketing device using Tapatalk
          Firmwares HERE
          • allan
            RTFM!!
            • 5459
            Re: K drum for c224
            you can do the DV's too. Shhhhh dont tell any one.
            Whatever
            • copier tech
              • 8103
              Re: K drum for c224
              Dont need to bother with the chips for drum & dev unit can simply turn off the warning in CE mode.
              All you do when fitting a black drum as colour is to use the old chip.
                • 14376
                Re: K drum for c224
                Except for the fact that the machine adjusts for a new drum when you install it. If you don't at least use a new chip the machine won't know it is a new drum and therefore can't make those necessary adjustments.
                • allan
                  RTFM!!
                  • 5459
                  Re: K drum for c224
                  Jip drum aging adjustment is a factor. The increased charge will fry the new drum surface.
                  Whatever
                  • copier tech
                    • 8103
                    Re: K drum for c224
                    Rubbish, a good tech can monitor print quality & replace drums etc as required, why replace an imaging unit when it is printing perfectly?
                    • allan
                      RTFM!!
                      • 5459
                      Re: K drum for c224
                      No not what i meant. it needs to be reset if you install a new drum. you can reset old drums along as the quality is still OK.
                      The machine changes the voltages as some of the parts gets older to compensate for quality loss.
                      Resting drum and dev counts and other counters on production machines is critical.
                      Whatever
                        • 14376
                        Re: K drum for c224
                        Rubbish, a good tech knows that the machine adjust voltages as drums age. He/she doesn't skimp on service just to save a couple bucks for the price of a drum chip.
                        • fishleg
                          • Mar 2009
                          • 425
                          Re: K drum for c224
                          So do you think this can cause dev depletion? If the drum counters are never reset and the old chip just stays on the drum?
                          I've seen a lot of black devs deplete there dev but its always been due to cheap toner which wasnt replenishing the dev. We have left old chips on machines for years with no ill effects. We check drums on regular call outs and replace when necessary but usually just leave old chips on except black.
                          Sent from my D6603 using Tapatalk
                          • dickierock
                            • 252
                            Re: K drum for c224
                            Hi, what settings do I change in service mode to turn off drum life.
                            Do any other warnings/errors show up on the display at end of drum life?
                            Thanks in advance.
                            • allan
                              RTFM!!
                              • 5459
                              Re: K drum for c224
                              You need the right firmware. Like C? or higher.
                              Change SW51 to HEX30. At lease around here where i am!
                              Whatever
